How to disable message center
Car: 1992 RS Camaro
Engine: 383
My 92 RS was converted to a Carburated 650 cfm on a 383 and messages are not needed or accurate. How do I disable the message center?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Message Unclear
If you’re referring to the SES Light you can turn the light off by disconnecting the brown wire with a
White stripe at the ECM.
Happy Racing !
If You’re In Front Of Me DON’T Slam On Your Brakes Just Because Someone At The Head Of The Pack Is Spinning
Happy Racing !
Re: How to disable message center
INFL REST is the air bag, so it won't disable that one as it isn't controlled through the ECM. I'd just pull the cluster and take the bulbs out, personally.
Here is the back of cluster:
Only 4 of those bulbs are for the backlighting (the gray ones, I believe), the rest turn on certain lights (SES, INFL REST, Seat belt, Security, etc)
If you really wish to hack apart your wiring worse, here is the pinout for the custer. Just cut the wires leading to the cluster and tape them off:
I tried to find a nice picture with each of the bulbs labeled for you, but couldn't, and I don't have a 90-92 gauge cluster handy.
BrianH33478
Dec 17, 2015 03:05 AM
