1990 iroc no ecu where to wire vss signal to
Old Dec 27, 2015 | 11:41 AM
dcbsracing007's Avatar
Car: 1990 iroc-z twin turbo
Engine: l98 350
Transmission: t-56
i have a 1990 icoc that I have removed the entire ecu and stock harness for a fast xfi system. my problem is that I don't know where to wire the vss signal to on the c100 block. Ive looked at the pinout of a c100 block and its saying there are two possible locations which are not useable ports and the color of the wires don't match up. I have a t 56 and a Dakota digital. the output wire from the Dakota digital used to go to the purple wire into the ecu. I also would like my cruise control to work since all of the other parts are still there..
Old Dec 28, 2015 | 09:09 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruising & Amusing
Just make sure the VSS output is connected to the Cruise Module input at C209 20 AWG red wire no need for C100 for this purpose.
Happy Racing !
If You’re In Front Of Me DON’T Slam On Your Brakes Just Because Someone At The Head Of The Pack Is Spinning
Old Dec 28, 2015 | 08:28 PM
Engine: l98 350
Transmission: t-56
Re: Cruising & Amusing
thankyou much
vinny R
Jan 24, 2016 01:02 AM
dixie wrecked
Jan 12, 2016 08:10 PM
gnilson
Dec 9, 2015 12:39 PM
FiVe KiLLZ
Dec 8, 2015 08:02 PM
ziggy89
Dec 6, 2015 08:13 PM
