heated o2 sensor
Old Jan 9, 2016 | 03:03 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
heated o2 sensor
Ok, so Im replacing the o2 sensor, and will get a 3-wired heated.
I know there are many threads about this, but still cant the exact info I need.
Im going to wire the switched 12v+ to the Fuel pump relay.
My car is an 88 GTA, and it seems that the wiring colors are different for different years...
Here is what the relay looks like:
Connector:
Which wire from the relay connectors, should I splice?
The wire colors are:
Tan/White, Black/White, Dark Green/White, Orange, and Orange(Red).
Old Jan 13, 2016 | 02:34 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Re: heated o2 sensor
Anyone?
Old Jan 13, 2016 | 03:56 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by HasseO
Anyone?
The large Tan wire with the white tracer is the switched lead from the relay that powers the pump . Going with your plan of hooking it in parallel with the fuel pump , use that wire .
Old Jan 16, 2016 | 08:54 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Anyone?
I'm going to sound pompous or like I have a better than tho attitude but I mean well, I'm guessing if you're asking this you don't know how a relay works and you don't own a digital multi meter? It would really be helpful to you to spend an hour to do a Google Search and read the information about how a relay works and wiring relay projects. And any digital multi meter works fine when you're just starting out.
Old Jan 17, 2016 | 07:50 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You could just run the wire through a factory rubber grommet in the firewall and plug it into the IGN fuse/terminal.
purg3d
May 7, 2006 10:35 AM
UK Speedbird
Mar 3, 2005 10:24 AM
JeffC1500TBI
Apr 5, 2004 04:22 AM
