Gauge Troubles
Old Jan 12, 2016 | 09:01 AM
kaupca's Avatar
Car: 92 Camaro RS
Gauge Troubles
I have a 1992 Camaro with 350 engine. In the last couple of days the oil pressure gauge has started pegging out at the high end. Today the temperature gauge is swinging from side to side. Fan is running, thermostat is opening and system is full. The fuel gauge seems to be reading high. The tachometer is working OK. The voltage gauge is showing about 16 volts. Is there a common thread to cause all of these to be acting weird?
Old Jan 12, 2016 | 11:49 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: Gauge Troubles
Yeah...the cluster is going bad.
Old Jan 12, 2016 | 01:06 PM
kaupca's Avatar
Car: 92 Camaro RS
Re: Gauge Troubles
That being the case is there someone who repairs these?
Old Jan 18, 2016 | 05:46 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Re: Gauge Troubles
You can buy a rebuilt one on line, but they're pricey, $500, but some used also available at http://www.hawksthirdgenparts.com/se...rument+cluster.
Avoid those on Ebay.
No idea who'd repair one.
2012sergen11
Dec 29, 2015 03:04 PM
Aaron R.
Dec 19, 2015 11:01 PM
Galaxie500XL
Dec 19, 2015 10:09 AM
racerx520
Dec 14, 2015 12:29 PM
