No start issue
Old Jan 30, 2016 | 04:37 PM
rx8camaro's Avatar
No start issue
I had to do a battery relocation back to the stock position in my 1992 z28 l98. I had the car running for awhile shut it off and when i went to start it again for service it was no start. Key turns and all lights come on but nothing happens. Battery is brand new and tests ok. I have power down to starter and i can turn the starter over using my powerprobe to the solinoid and applying power to it. All wires and grounds are tight and clean. Here is what i found the power wire going from battery to starter must have rubbed against header and you can see exposed wiring where it touched and probably grounded off the header itself. Would this blow a fuse and which one? I checked the fuses i could see under left footwell area with a test light and they all test ok. Are there more fuses somewhere that i am missing? Thanks guys.
Old Jan 31, 2016 | 01:08 AM
rx8camaro's Avatar
Re: No start issue
Bump
Old Jan 31, 2016 | 08:20 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: No start issue
You have power from the battery to the starter on the large cable. You can turn the motor over by applying power to the solenoid but not with the key. Sounds like a VATS problem. Power goes from ignition switch to neutral safety (or clutch) switch then to starter relay and then to solenoid. You'll need to trace back from solenoid to see where you are losing the start signal. Remember, when testing for power, you need the key in start position so may need an extra set of hands. If you find that the starter relay is not being commanded on, then probably VATS and you will need to troubleshoot that problem. For wiring diagrams, AustinThirdgen has what you need.
Old Jan 31, 2016 | 08:34 AM
rx8camaro's Avatar
Re: No start issue
Thanks for the reply. I will look into the vats issue. I guess it was maybe just one of things i never had a issue with and i saw that power wire rubbed through and thought maybe that caused something to blow. Just one of those things you know. Thanks again
Old Jan 31, 2016 | 09:58 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: No start issue
" Here is what i found the power wire going from battery to starter must have rubbed against header and you can see exposed wiring where it touched and probably grounded off the header itself. Would this blow a fuse and which one? "
Check your Fusible links at the starter.
Old Jan 31, 2016 | 11:16 AM
rx8camaro's Avatar
Re: No start issue
Ok i will. The car is in the my shop so i will revisit everything on monday, thanks until then guys
Capone615
Feb 5, 2016 03:50 PM
carattini
Jan 12, 2016 12:51 PM
Ezgoin28
Jan 10, 2016 10:06 PM
3rd gen money
Jan 10, 2016 09:00 AM
kt350
Jan 7, 2016 04:39 PM
