Code 15
Old Feb 15, 2016 | 04:06 AM
chevrundeep92's Avatar
Car: 92 rs
Engine: 305 tbi
Code 15
92 camaro rs for code 15. Changed the ect, took battery cables off waited a little bit hooked them Back up started the car then did diagnostics on it....still came back up. I tested the cables coming form the ecm with the key on took a voltameter...no reading...could this just be a bad wire or am I doing something wrong. I also tested the new sensor while I put It in hot water and took the voltameter to it...as the water got hotter the reading went down. Has anyone had the same problem. ...someone point me in the right direction
Old Feb 15, 2016 | 12:04 PM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: Code 15
Coolant
sensor circuit
(All)
See note for code 14.
Faulty
or loose wiring and/or connectors from the coolant sensor.
Faulty
coolant sensor.
Faulty
or loose wiring and/or connections at the ECM.
ev305tpi
Feb 4, 2016 08:40 PM
88Birdman
Jan 31, 2016 05:43 PM
racereese
Jan 25, 2016 07:13 PM
86_firebirdTA
Jan 21, 2016 08:46 PM
89 formula TPI
Jan 18, 2016 03:13 PM
