Temporary vats fix
Old Mar 23, 2016 | 07:23 PM
primergrey91rs's Avatar
Car: 91 Camaro RS
Engine: 3.1 v6
Temporary vats fix
Hey, i was wondering: if i ripped the speaker off a headphone and plugged the positive wire into the vats signal wire to the ecu, would i be able to play a 30 hz tone and trick the ecu into thinking the vats is operational?
Old Mar 23, 2016 | 08:21 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Temporary vats fix
No .
Old Mar 23, 2016 | 09:14 PM
Car: 91 Camaro RS
Engine: 3.1 v6
Bummer, my vats module went bad, so I built a little circuit to send the 30hz signal to the ecu. Well i must have done something wrong, as i only have a basic understanding of electronics and the circuit i built stopped working after 4 or 5 times starting my car. So I ordered one on the interweb and I'm just trying figure something out for until it gets here as this is my daily driver
Old Mar 24, 2016 | 01:33 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Why not go to radio shack and spend less than a couple dollars on some resistors and wire it in?
Old Mar 24, 2016 | 03:03 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
First determine if the module itself or the lock cylinder. Then you either have to bypass the starter relay and get VATs deleted off your prom, or find the resistance in your key and put that resistance into the wiring going from the ignition (tricks the box into thinking the key is always there). Don't try "experimenting", that can really mess stuff up.
How did you come up with 30Hz? Where were you tapping it into?
Old Mar 24, 2016 | 07:59 AM
Car: 91 Camaro RS
Engine: 3.1 v6
I had the resister bypass for a while and it stopped working. I'm rather certain it is the vats module that is bad, as I've tested continuity on all wires involved and they check out.
Old Mar 24, 2016 | 08:10 AM
Car: 91 Camaro RS
Engine: 3.1 v6
The resister bypass is no longer working. It is my understanding that when the proper resister value is read, the module itself sends a 30 hz signal to the ecu, upon recieving said signal the ecu enables the injectors. I'm talking about tapping into the blue wire that goes from the vats module to the ecu
Old Mar 24, 2016 | 02:47 PM
Engine: LB9
Axle/Gears: 3.08
My bin requires 33 - 66hz. If yours is the same you should be aiming for closer to 50hz.
Apparently yours is supposed to be a 30hz signal.
Or it could be a voltage issue.
THIRDGEN87
Interior Parts Wanted
Aug 24, 2023 01:01 PM
knightinblackar
Jun 6, 2016 05:24 PM
87gtaredonred
Mar 31, 2016 12:31 AM
Lurbie
Mar 21, 2016 08:57 PM
Terron Moore
Mar 19, 2016 05:23 PM
