got rid of the ecu
got rid of the ecu
hey I'm new to this forum I have a 1988 trans am gta and I have swapped a carbed 350 into it and made a new wiring harness to get rid of the ecu but now the speedo and radio don't work do they run through the ecu and if so how can I get them to work without wiring the ecu back into the car? Thanks
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Radioactive
The ECU has nothing to do with the radio therefore you might have accidentally disconnected something.
Trace the power wire back from the radio to find out where the break is.
Happy Racing !
Help Combat Global Cooling ▬ Accelerate As Fast As Possible
Happy Racing !
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: got rid of the ecu
This might be the answer to your Speedo problem,.....
https://www.thirdgen.org/forums/elec...nsmisison.html
FYI: This thread is just 5 posts below yours. You didn't even have to SEARCH to find it,... you would have found it just by looking at the page.
