ls tank WIRING stock guages
Old Apr 12, 2016 | 01:24 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
Can someone draw a wire diagram for ls1 fuel tank with stock guages?
from what i understand i need to add a ground and a resistor in fuel sender wire?? im looking for a visual im not exactly clear from reading the posts ive found
Old Apr 12, 2016 | 01:26 PM
Twin_Turbo's Avatar
Re: ls tank WIRING stock guages
instead of hacking up stuff, get a fuellink module. You can taylor your level to the LS sender, you can set a low fuel light and it has a delay buffer so no bouncy needle.
Old Apr 13, 2016 | 12:29 AM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
http://www.tanksinc.com/index.cfm/pa...rod/prd473.htm
Like this one or something better you know of
Old Apr 13, 2016 | 01:04 AM
Twin_Turbo's Avatar
That's it, cheaper here
http://www.yogisinc.com/index.cfm/pa...d/prd16424.htm
Old Apr 13, 2016 | 01:50 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
so stock guage wire goes to gauge terminal on module?
how do ls1 wires input to module?
(A)fuel level input
(B)fuel pump control
(C)fuel pump ground
(D)fuel level sensor ground
91banditt2
Aug 11, 2021 10:54 AM
racerx520
Apr 13, 2016 09:54 AM
Beau27
Apr 12, 2016 10:31 AM
martindforsythe
Apr 10, 2016 03:54 PM
Chough262
Apr 10, 2016 01:20 PM
