1987? Camaro C207 Wiring help!
Old Apr 15, 2016 | 08:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I'm trying to convert what I believe is a 1987 Camaro Automatic V6 harness to plug into my dash harness. Should be plug and play, right? Not so. I have 2 wires in the engine harness I have no idea what they're for in the C207 by the ECM. This is going into a manual trans car with trans mounted VSS. Already have tucked wires for the reverse switch and VSS into harness and will be adding relevant connectors shortly as well as converting IAC and TPS connectors over to 3.1 connectors.
B: Solid orange wire. Runs to fuel pump relay connector. ALDL G? Thought that was red?
G: Black wire with TWO red stripes. Have no idea where this thing goes. Yes, it's 2 red stripes, one on either side of the wire. Only wire I can think of that's black and red that is 18 gauge is the reference pulse ground wire for the distributor but that only has one stripe. Other wire that is that color is the fat one for the coolant fan.
B needs to go in favor of one of the fuel injector power wires. G needs to go for same purpose. Trying to delete the 6 cavity, 3 terminal C221 connector that has the fuel injector and fan relay/alternator sensing tan/white wires in it since dash harness does not have said connector and I don't have the connector body for these terminals. Everything needs to go into the C207.
Old Apr 16, 2016 | 10:40 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 1987? Camaro C207 Wiring help!
Here is the C207 Pin-out for the 87:
1986 & 1987 C207 ( TPI )
PIN Color From / To (Notes)
A Brn ALDL / ECM (AIR control)
B Red ALDL / Fuel Relay ( TPI )
C Brn/Wht ECM / CE Light ( TPI )
D Tan/Wht Fuel Relay / Fuel Pump ( TPI )
E Wht/Blk ALDL / ECM (test)
F Pnk/Blk IGN fuse / EGR-ECM
G Pnk/Blk Gage Fuse / Burn Off Relay ( TPI )
H Tan/Blk ALDL / TCC-ECM
J Org ALDL / ECM ( TPI )
K Brn ECM / Speed Buffer
L Tan/Wht Fuel Relay / Fuel Pump ( L69 )
M Blk/Wht VSS,P/N switch / Grd
N Org/Blk ECM / P/N switch
P Ppl Brake / TCC
R Ppl/Wht Crank Fuse / Cold Start-ECM ( V6 )
Plug C221
A Pnk/Blk Inj2 Fuse / Even Fuel Injectors
B Lt Green Back Up Switch / BU Lights ( V6-T5 )
C Brn Fuel Pump-Fan Fuse / Fan Relay ( V6 - TPI )
D Pnk/Blk Inj1 Fuse / Odd Fuel Injectors
E
F Dk Blue Back Up Fuse / Back Up Switch ( V6-T5 )
Sometimes a wire will change from one side of a connector pack to another. ( I seem to remember this was the case for BI injector wires on later cars ?? ) The only way to BE SURE about each end every wire is to trace that circuit using the factory shop manual schematics. ( and even those are not 100% accurate sometimes ! )
Old Apr 16, 2016 | 10:44 AM
John in RI's Avatar
Since your car is an 88,.. here is the 88 C207 info:
Edit: Here is the 'disclaimer I wrote after making the PIN charts:
"On several of the diagrams the wire color changed from one side of the plug to the other ( dash harness vs. ECM harness.) In this case I used the DASH harness color ( some ECM harness side wire colors specified in"
1988 C207 (maybe 89 too)
A Brn ALDL (pin C) / ECM (AIR control)
B* Pnk (Red) INJ1 TBI (TBI)
B* Pnk/Blk (Pink) INJ1 (V6)
B* Pnk/Blk (Black) INJ1 (TPI)
C* Brn/Wht ECM / CE Light
D* Brown (Tan/Wht ) Fan
E Wht/Blk ALDL (pin B) / ECM (test)
F Pnk/Blk IGN fuse / ECM
G* Pnk/Blk (White) INJ2 TBI (TBI)
G* Pnk/Blk (Pnk/Black) INJ2 / (V6)
G* Pnk/Blk (Black) INJ2 (TPI)
H Tan/Blk ALDL / TCC-ECM (auto)
H Tan/Blk ALDL / Upshift (stick)
J* Org ALDL (pin E) / ECM
K Brn/Yellow (brown) ECM / Buffer
L Drk Blue (purple) Vats to ECM
P
MelodyS
Camaros Wanted
Apr 21, 2016 08:00 PM
fadetoblack
Apr 15, 2016 08:44 PM
beachrodder
Aug 25, 2015 08:05 AM
scorchmaster
18
Oct 27, 2011 09:43 AM
InfernalVortex
Carburetors
Jan 20, 2008 09:06 AM
