A/F Gauges
Old Apr 21, 2016 | 11:42 AM
1987thirdgen's Avatar
Car: '87 RS, '88 Trans Am, '91 Formula
Engine: 5.0, 5.0, 5.7
Transmission: T5, 700r4, 700r4
Axle/Gears: 2.73, 2.73, 2.73
A/F Gauges
Looking to install a wideband A/F gauge so I can play with nitrous.
Two questions:
Anyone using innovate gauges/ data logger?
Can I get by with one sensor in the Y-pipe, or do I need to run a sensor in each collector for each bank?
10.2:1 comp ratio 305, warmed cam, edelbrock dual plane- holley 1850- shorty headers to 3.5" single pipe- dumps out the rocker mid-vehicle.
Old Apr 22, 2016 | 09:33 AM
skinny z's Avatar
Re: A/F Gauges
I'm using the Innovate data logger and another brand of A/F gauge. That means that the single O2 sensor I have has be to disconnected from the gauge and connected to the data logger.
With the Innovate gauge, data logging can be done with both devices connected to a single sensor.
For all intents and purposes, either set up will work just fine. While there may be slight difference in A/F ratio between one bank of cylinders and the other, I haven't found it to be an issue in tuning. I had at one point the O2 sensor installed in the opposite header and my data is pretty much the same.
Old Apr 23, 2016 | 11:07 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: A/F Gauges
I just started using the MTX-L for tuning with my carb. It works great with the O2 sensor in one header collector.
I haven't tried the data logging output.
Old Jun 3, 2016 | 12:16 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: A/F Gauges
So is the wideband sensor in the location on the header as the O2 sensor?
Old Jun 3, 2016 | 07:28 PM
skinny z's Avatar
Re: A/F Gauges
The wide band sensor IS the O2 sensor and the closer it is to the cylinder head, the better. That's places it in one of the header collectors.
Old Jun 3, 2016 | 09:04 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Re: A/F Gauges
I am using the innovate gauge/kit. So far so good running my ecm from it. I dont have the gauge installed yet but it will do both. I have the LC2.
Old Jun 4, 2016 | 10:00 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: A/F Gauges
I have the LC2 Sensor hooked to my ecm and it's worked out great. Ideally you want the sensor to be as close to or in the header/manifold collector as possible especially if it is not a heated sensor. If you have a carb then just putting one in one of the header collectors will be fine. If you have efi running one in each collector can be very useful. You can use it if you have a fuel/spark problem to easily see which side of the engine it's on and if it's a rich or lean issue.
Nutti
May 14, 2016 01:33 PM
ama2212
May 6, 2016 10:13 AM
ponttpi86
Apr 27, 2016 09:28 PM
midnightfirews6
Apr 25, 2016 07:14 AM
84 1LE
Apr 22, 2016 06:21 PM
