Fluctuating fuel gauge pointer
Old Apr 16, 2016 | 01:44 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Hows everyone pointer on their fuel gauge?
Does it bounce around some?
How common is this?
My issue is mostly during braking/accelerating & more so again in the lower half range.
Using the plastic fuel tank (01) with the OE sump/float, aftermarket pump, speedhut gauge.Doubt the gauge/pump have anything thing to do with it, since the pointer is reacting to the float moving up/down...right.
Old Apr 18, 2016 | 04:10 PM
R13_Braz's Avatar
Car: 2014 Z28 #80
Re: Fluctuating fuel gauge pointer
Mine does this heavily, even in the stock tank. There's baffles in it, and still does it. I've just come to expect it.
My wife's 91 with stock everything does it too. Especially in the lower half of the range.
Old Apr 18, 2016 | 04:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thought the OEs would've had this solved by now.My 99 s10 aint so bad compared to my Camaro.
Old Apr 18, 2016 | 06:03 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
They have. It is handled by trending algorithms in software for gauges that are run by an ECM. Our gauges are wired directly to the float so if the float goes up, then guess what happens......
The only thing that slows it down is the damping built into the gauge.
Old Apr 20, 2016 | 11:40 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Anyone make a "buffer" device to steady the needle?
Old Apr 22, 2016 | 05:28 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Do you think it's in the computer? Kind of like how the 99+ temp gauge shows the average rather than real time? Just a thought as I'm not sure how that works...
Old Apr 22, 2016 | 06:21 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Nah, not for my application, no gauges are computer monitored.
Gray Ghost 8991
Apr 24, 2016 10:45 AM
racerx520
Apr 17, 2016 07:14 PM
87zz28
Apr 16, 2016 06:27 PM
wadem69
Convertibles
Apr 15, 2016 11:41 AM
racerx520
Apr 13, 2016 09:54 AM
