Headlights blowing fuse
Old Dec 26, 2001 | 08:44 AM
Prem's Avatar
Hi, I have a 87 GTA 350 TPI and my headlights wont go down.
I read somewhere that is could be the tail light fuse. So I changed it and the light went down. I thought I solved the problem until I used the lights again and the same thing happened. It keeps blowing the fuse. Any one have any experience with this problem? The fuse is 75 amps and the motor on the light seems to run about 3-5 seconds after it comes up. The lights still come up when I manually turn them down.
Prem.
Old Dec 26, 2001 | 08:46 AM
DiecastZ28's Avatar
Are you sure nothing is touching? Something must be shorting out for you to be blowing fuses like that. It only happens when you turn the lights on, make sure nothing is touching.
Old Dec 26, 2001 | 10:38 AM
Prem's Avatar
can anyone tell me where I can find the electonic control module fior the headlight doors is? I feel the problem is there.
3rd gen money
Oct 11, 2019 09:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
