Rpm gauge stopped working?
Old Jul 17, 2016 | 02:52 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
What's up guys I got a 91 trans am with a 350 tpi. I recently fixed the fan relay and got that working properly. I started it up and drove around to get it to operating temp. As I was pulling into my garage I noticed the rpm gauge had stopped working. It was working fine when I was driving. I checked the white wire coming off the coil and it seems to be I tact it's not broken or anything. What else should I check? I've read the sticky on them. But this one was working fine I didn't have any problems with it.
Old Jul 17, 2016 | 03:12 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Rpm gauge stopped working?
Have you checked that the 1-wire connector (primarily tan wire with stripe I think) that is near the distributor is connected and has a good connection? The one you disconnect when doing timing. If that's disconnected it will make the tach read 0, I had one come apart on me before.
Old Jul 17, 2016 | 03:30 PM
Engine: 350 tpi
Yes I checked that it all is connected.
Old Jul 17, 2016 | 04:36 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Is that the oy issue?
Do the gauge lights & other gauges work?
I wonder if there is a blown fuse.
Old Jul 17, 2016 | 06:25 PM
Engine: 350 tpi
Yes everything else works all the other gauges work. How can I check the wire in the coil? It is the white one in the front of the coil correct?
Old Jul 18, 2016 | 09:29 PM
Engine: 350 tpi
Bump I went over everything today to be sure the tach wire is the white one next to the pink one in front of the coil correct? There is also a plug there with a connector
Bryanm254
Mid-West Region
Apr 1, 2016 12:31 PM
Titan1833
Mar 27, 2016 03:11 AM
RARE-ROC-Z
Aftermarket Product Review
Dec 26, 2000 11:26 PM
chevystud
Oct 16, 2000 06:18 AM
Black Beauty
Sep 28, 2000 10:08 AM
