4th gen dash + stock V6 dizzy = bouncy tach?
Old Jul 22, 2016 | 12:54 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Okay, threw a bone stock V6 3.1 in the 88. Having issue between distributor and tachometer. Engine runs well enough, hopefully the miss is gone with fuel pressure fix. Problem I'm having is with a bouncy tach in my 94 cluster that also seems to be reading a bit off. Didn't have any issues with the 3x00 setup but this bugs me. Only thing I know for sure is the engine harness has a quick tap in it for probably an aftermarket tach. Don't see any damaged wires or anything other than that. Dash harness is untouched... Engine harness modified to match with addition of T5 reverse switch and trans VSS. Scratching my head here.
Forgot to mention ignition module is brand new and has less than 2 hours run time. Second module does the same.
Old Jul 23, 2016 | 03:08 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: 4th gen dash + stock V6 dizzy = bouncy tach?
Well, now the tach wire is disconnected from coil pigtail... No more bouncing tach. No more tach period. So how am I going to set my minimum air rate now?
cainestl
Exterior Parts for Sale
87
Mar 26, 2013 11:05 AM
danielmonster
Apr 4, 2009 05:53 PM
Cam-aro
Dec 2, 2006 12:29 AM
mult68
Jan 12, 2001 12:03 PM
