Here's what I got
Old Jul 23, 2016 | 08:00 PM
Finally Got one's Avatar
Here's what I got
86 T/A TPI
Changed MAF. Changed Maf power relay. Changed Maf burn off relay. Changed maf a SECOND time. Still throwing code 33 and 36. Now, after replacing new duralast maf with ANOTHER new duralast maf, noticed slightly different behavior, with first maf it would stumble on throttle application, with replacement maf it revs fine just won't stay running and runs richer than Trump. I'm guessing I need to hunt down another MAF do you guys agree?
Old Jul 23, 2016 | 08:21 PM
Re: Here's what I got
Correction....with MAF connected I get no codes but runs like turd. Also, any suggestions on brand?
Old Jul 23, 2016 | 09:41 PM
Theoretically could it be o2 sensor?
Old Jul 24, 2016 | 11:22 AM
Cleaned the **** out of original maf, reinstalled, runs a lot better but now have code 34. Keep in mind I just replaced both maf relays according to this info
Old Jul 24, 2016 | 11:39 AM
OrangeBird's Avatar
Car: 1989 Firebird
The one thing I can tell you is this ;
I have seen literally dozens of threads of MAF troubles and most come down to not being able to get away with buying a cheap , especially "rebuilt" , MAF . If you do a search using the words "defective MAF" you find an afternoon's reading and will find which brand is trusted (can't recall which , but the one I bought was a couple of hundred , some years back) .
Oh , and , congrats for finally getting one !
Old Jul 24, 2016 | 01:44 PM
Thanks bro!
Old Jul 31, 2016 | 08:18 PM
You gotta be kidding me....put the FOURTH one on today, runs good but throws a code 33 instead of 34 FML. I'm convinced its the maf because I've gotten different results with all four of them. I want to try a delco but the only place that has one has a no return policy don't wanna be out 300 bucks
Old Aug 1, 2016 | 11:31 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
$300 for piece of mind and knowing it's good to go and will probably fix all your troubles? Sounds cheap.
Old Aug 1, 2016 | 12:27 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Instead of a Delco MAF, which is just a Bosch unit anyways (aka same as you're buying, just new not refurb), how about you try one of the new Richporter ones? It's an entirely different design. Richporter MA157. I paid $150 new, and have not had any problems. Oreily carries them I believe, if not the Fleabay has them all over.
That being said, 4 MAFs and continued issues would make me start looking elsewhere into my troubles before buying even more MAFs.
Old Aug 1, 2016 | 12:46 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I had all kinds of trouble with MAF sensors or what I thought was the problem with a car years ago. Wound up changing distributor and maybe the coil and no more problems.
Old Aug 1, 2016 | 12:52 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
For everyones information......
Rich Porter was acquired by Spectra in 2014
Acquisition of Richporter Technologies, which extends Spectra Premium product line coverage into engine management parts
spectrapremium
Old Aug 1, 2016 | 12:55 PM
thtanner's Avatar
spectrapremium
Correct.
Most parts took a quality hit, too. The MAFs seem fine, however, and are still the 'new-style' design.
They own the name and still market some products as Richporter by Spectra too, just to confuse everyone more.
Old Aug 1, 2016 | 06:46 PM
Thanks 4 the input guys...I'm going to order the Walker from RockAuto and if that doesn't work I'm going to go delco and take a loss. I'm convinced its the maf as everyone I've put on has exhibited different behavior
Old Aug 1, 2016 | 06:51 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Rich Porter is the way to go. $150 bucks. But hey, its your money. Good luck with it.
Old Aug 1, 2016 | 08:43 PM
So the Spectra is the rich porter? I could do the that to match the rest of the parts I used to make a cold air intake lol
Old Aug 1, 2016 | 08:44 PM
thtanner's Avatar
Yes
Part number MA157
Will look different (inside) than the Bosch units.
Old Aug 1, 2016 | 08:46 PM
thtanner's Avatar
Also your cold air intake setup isn't ideal. Heck, it's down right bad for the car.
The MAF needs non turbulent air, aka through a strait section of pipe, to give accurate readings.
Put the stock setup on and see where it gets you........
Old Aug 1, 2016 | 08:49 PM
I would but I don't have it...bought it with a ripped up stock snorkel attached to pipe pictured...chopped the pipe to make it fit. Dude that had it botched it up pretty bad....fan switch where the sender was supposed to go jumper wire from batt to burnt up fan relay pigtail etc
Old Aug 1, 2016 | 08:51 PM
thtanner's Avatar
See what you can do about replacing the bendy party of the tube with a strait section, put the MAF in the middle (similar to a stock setup).
Turbulant air will just kill the MAFs ability to read accurately
Old Aug 1, 2016 | 08:55 PM
Will do! Not comfy with the way it is now anyway just had to do something about the way it was...hood was contacting filter on way down with prior setup
Old Aug 1, 2016 | 08:58 PM
Unbelievable that I can't find a specific cold air kit for a car of this popularity
Old Aug 2, 2016 | 10:52 AM
Engine: LB9
Axle/Gears: 3.08
The market dried up. No profit in making one cold air kit a year for the guy that just bought the 2+ decade old red-headed stepchild of GM.
Old Aug 2, 2016 | 11:21 AM
thtanner's Avatar
You can buy one of these, worst case.
http://www.ebay.com/itm/361573397640
I'd suggest a better filter, and building a housing around it to separate the rest of the engine bay from the filter, but hey, it will work way better than that's in there now.
Old Aug 2, 2016 | 10:31 PM
Thtanner thanks!
Old Aug 3, 2016 | 02:17 AM
777Shock777's Avatar
Engine: 5.7!
For what its worth, I bought that one on ebay that thtanner recommended.
It fits with no problems, the MAF is supposed to have a little bracket thing that attaches to the upper radiator support/cover.
I can send a pic if you need to see the stock layout
Old Aug 3, 2016 | 06:01 AM
If u can that would be great
Old Aug 3, 2016 | 10:58 PM
Engine: 5.7!
Here you go, if you need another pic at another angle or something, let me know. (Yes I got the red intake & yes it sounds good when flooring it haha).
But you can see the metal bracket that uses two bolts on the pass. side of the upper radiator support/shroud.
Old Aug 4, 2016 | 12:30 PM
Sharp set up. That's the intake from eBay? If so ordering it tonight. Also, that bracket is long gone but I shouldn't NEED it to mount maf right? Not at home to check but I don't believe my mass pigtail would reach that far
Old Aug 4, 2016 | 02:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
After 4 MAF replacements,I don't know!!I don't think your problem is the MAF sensor, I think it's your setup
Did you check for vac leaks??
Old Aug 4, 2016 | 03:51 PM
I couldn't find any, then again don't know what havoc po did...I know smog pump not hooked up AC is gone but all hoses look in order and no glaring leaks...setup, while unattractive, is locked down airtight
Old Aug 9, 2016 | 12:07 AM
Engine: 5.7!
Yep that's the one from Ebay, they have lots of different colors and different piping styles. Check the seller "cmpautoparts11"
This is the one I bought: http://www.ebay.com/itm/BLACK-RED-19...EAAOSwcF9UXxL-
Not bad for $55 - I DID have to do just a little cutting on the black rubber parts to make it fit perfect, not hard at all.
Old Aug 26, 2016 | 09:17 PM
Here's an update...I've left it alone because its running well with 34 code. I ordered one from rock auto, a Walker that came with test slips and all. So I replace intake parts, throw maf higher up the pipe right before 90° to go into throttle body and walah....it runs like GARBAGE. I let it run for about 5 minutes and it started smoking back by distributor. I unplug maf, and it runs like a top. I'm at the end of the road with this guys...its insane
Old Aug 27, 2016 | 09:06 AM
Would air charge temp sensor located on rear of intake manifold play a role here???
SteelheadBen
Jul 31, 2016 10:49 PM
warlord
Apr 16, 2016 05:23 PM
nuggie
Apr 3, 2016 08:58 PM
89TA WS6
Apr 1, 2016 10:09 PM
krisb410
Mar 17, 2016 05:51 PM
