Headlight Switch issue?
Old Aug 2, 2016 | 04:42 AM
Red5's Avatar
Car: 1992 Firebird Convertible
Transmission: Not sure. It's an automatic
Axle/Gears: Not sure.
My headlight switch on my 1992 Firebird works fine when I turn on the headlights. Everything comes on. However when I turn on just the parking lights, my headlights flip up but the lights stay off. Why is the headlight motor recieving a signal to actuate? Is this possibly a bad switch? I have replaced a few bad bulbs recently (I've owned the car for three weeks) and I know years ago 1994-ish I had some crazy electrical issues arise from installing a wrong tail light. But to the best of my knowledge all the lights that I have changed have been correct. I have changed a fog light, a shifter light and a drivers side tail light.
Any info would be helpful
Old Aug 15, 2016 | 04:36 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Head Of The Class
In the headlight switch there is an element responsible for actuating the marker lights and the motors independent of the headlights.
It sounds like the element is touching the second contact early.
Use an ohmmeter to verify then replace the headlight switch.
Happy Racing !
Whether The Street Car At A Traffic Light Or The Nitro Funny At The Strip, Yellow Means Floor It !
Old Aug 15, 2016 | 05:50 PM
Red5's Avatar
Re: Headlight Switch issue?
Thank you so much! I suspected the switch. I really appreciate the response.
Old Aug 15, 2016 | 05:56 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
I also have this problem intermittently, so I'd be curious to the results of replacing the switch. When I had mine apart to clean I didn't really see how it could contact the other one early, but you never know.
Old Aug 15, 2016 | 06:19 PM
Red5's Avatar
I would imagine the switch could go bad. It is responsible for doing a lot. It turns on the parking lights, fog lights and interior lights with the one section, and the headlights and the headlight motor with the second part. I know several wires work go into a plug that goes into the back. I'm sure corrosion anywhere would cause a short. I just didn't want to change the switch for no good reason.
gt4373
Mar 23, 2016 02:18 AM
I_R_GRUNT
Mar 20, 2016 11:03 AM
herb17024
Mar 20, 2016 08:25 AM
gertie3993
Exterior Parts Wanted
Mar 18, 2016 12:08 AM
tecboy
Mar 16, 2016 09:52 AM
