What is this plug??
Old Aug 21, 2016 | 03:40 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
What is this plug??
It's a 86 Camaro. I have no idea what this is. It was mounted behind the dash
Old Aug 22, 2016 | 09:04 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: What is this plug??
That is (was) the module that took a signal from the original ECM and used it to activate the check engine light . It was only found on cars that were originally "CCC" (Computer Controlled Carb.) according to what I've been told . If you have the Vortec swap listed in your avatar and especially if your not using the original ECM , it's about as useful to you as disc brakes are to a turtle , eliminate it when your cleaning up all that nasty wirenut business I see going on in the rest of your picture .
PS , don't throw it away though , even if your car will never use it again , instead consider offering it up in the for sale section for like $10 or $15 plus shipping for someone who does have an intact CCC system who may need it .
Old Aug 25, 2016 | 07:29 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I appreciate the reply. I was wandering if that's what it was because all the wires went to the ECM plug. Yeah I never throw that stuff away. I'm doing a full 4th gen dash conversion not a half a** job either but 100% full ac/heat so it will work the way it's suppose to. That's why there is so many wires in the picture lol
Old Aug 25, 2016 | 09:40 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
No wire nuts here.
Old Aug 25, 2016 | 10:29 PM
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I have never used wire nuts. Or crimps I Sauder all my joints. That was the previous owner. You would not believe the mess I have had to clean up
Old Aug 26, 2016 | 12:31 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Yup,... It's a lamp driver module, I've only found them on Carb & Crossfire CCC cars. ( Not used with MPFI or FI )
Old Aug 28, 2016 | 10:16 AM
OrangeBird's Avatar
Car: 1989 Firebird
John I have to ask , where you say "Carb & Crossfire CCC cars" does this mean that the Crossfire was two CCC carbs ? I had always thought the Crossfire was two TBI units only and not two CCCs (computer controlled carbs) ? Or were the earliest Crossfires two CCCs and later became two TBIs ?
Old Aug 28, 2016 | 11:26 AM
John in RI's Avatar
I don't know much about the crossfires,... I've only owned 1 and it was removed for a non CC Carb engine. I'm pretty certain that the crossfire was 2 TBIs. I probably should have written "Factory Carb & Crossfire CC cars" with the "CC" meaning "computer controlled" to be a bit more specific.
With these cars the ECM light was managed using the Lamp Driver... ( ECM to Lamp Driver to warning lamp ), but the "Fuel injected cars" ( MPFI, TPI, & Even TBI ) used a direct connection from the ECM to the warning light. I assume the crossfires used the Lamp Driver because that is how all the other early Thirdgen ECMs were already designed.
Some time ago I converted a 86 MPFI V6 Firebird to a factory computer controlled carb ( 86 vintage) and in order to have a fully functional CE light I needed to wire a Lamp Driver "in-Line" so that the original V6 dash harness would properly handle the ECM light signal being supplied by the stock V8 ECM. I don't remember exactly how I did it at the moment - but it wasn't too difficult to figure out.
P.S. I also recall that the Lamp Driver in the carb cars used a GREEN case like shown above, but the Lamp Driver on the Crossfire dash harness was mounted inside a BROWN case. Probably means nuthin',........ just something I remember being different !!
ChevyKen
Interior Parts Wanted
Sep 11, 2016 08:52 AM
rh76camaro
Aug 19, 2016 08:47 AM
RunawayRadio
Aug 16, 2016 08:31 PM
aseychell
Aug 16, 2016 08:42 AM
zracTA
Aug 15, 2016 05:42 AM
