Thinking of making one big engine plug.
Old Dec 27, 2001 | 06:24 PM
92RSB4C's Avatar
Well, I started in on the engine rebuild and it's a lot of trouble!!! Those GM people couldn't engineer a car if their lives depended on it. Anyway, I've had a lot of trouble with pulling all the electronic connectors from the engine, so here's my thought. What if I cut all the wires going to the engine and spliced in a large connector so I could pull the engine without taking off all the connectors. Do you think it would work and do you think it would be too hard to do?
Old Dec 27, 2001 | 06:32 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Noy related to your topic but i checked out your website and seen a picture at the bottom with a Gulfstream GV in the far background. Do you come from a well to do family or what?
BTW, I work at Gulfstream in Savannah, GA.
Old Dec 27, 2001 | 07:19 PM
92RSB4C's Avatar
My dad's a pilot, so I got a shot with the airplanes. Maybe you've met him. He got stuck in Savannah when the 9-11 attacks were going on.
Old Dec 27, 2001 | 07:22 PM
92RSB4C's Avatar
If I made an engine connector, how would it be affected by moisture?
Old Dec 28, 2001 | 12:47 AM
Jza's Avatar
Jza
Depends on the type of connector you used.
Old Dec 28, 2001 | 09:37 PM
JAY87GTA's Avatar
I'm not sure about others, but I know that Ford did this with their powerstroke diesels. One big connector, unhook the starter and grounds, and the electrical is done. As long as you use a sealed connector you shouldn't have a problem.
Old Dec 28, 2001 | 09:39 PM
92RSB4C's Avatar
What about the connector used a where the engine compartment and the interior meet (at the firewall)? I think it's code named "C100".
Old Dec 30, 2001 | 09:23 PM
92RSB4C's Avatar
Ok, scratch that idea. The C100 only has 14 wires to splice and the engine has nearly 50! Any ideas on what connector would have 50 wires?
Old Dec 31, 2001 | 10:23 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Other than some kind of computer cable (SCSI, router or Digiboard) but those typically aren't sealed. The only thing then would be to get some sort of box to clamp over the wires on either side of the connector. I personally cannot imagine trying to get 50 wires from an engine bay lined up onto 1 connector. I see the advantages if the engine is in and out frequently. I have concerns about the varying voltages and "crosstalk" a single connector would produce. I would try and get all the 12v wires into their own connector (for troubleshooting electrical problems) and leave all the sensors for another. FWIW I thought that under the passengers fender was a very large connector already. Doesn't that help?
Old Dec 31, 2001 | 01:28 PM
Engine: 4.0L
Originally posted by cg91ta
....... FWIW I thought that under the passengers fender was a very large connector already. Doesn't that help?
That's not a connector but a protective covering to prevent shafing of the wires.
Old Dec 31, 2001 | 01:30 PM
Engine: 4.0L
Yes, I can get 50 pin connectors. Airplanes always use those kind of dissconnects. Weather tight also. Interested?
Old Dec 31, 2001 | 07:34 PM
92RSB4C's Avatar
Airplanes huh? I'll check with my dad and several people at the hanger tomorrow to see if there's any leftover. If not, do you have one I could use?
Old Jan 1, 2002 | 02:20 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Why not use 2 or 3 smaller plugs ?
Re-routing the wiring will eliminate alot of what you would normally have to unplug/move when pulling a motor (& alot of headaches when doing normal maintenance on the motor). I ran a majority of wiring thru my trans tunnel. When I was having lots of motor problems awhile back, I could just pull my intake & lay it on the windshield cowl w/o having to unlug anything.
If you don't mind the curiousity, how often do you plan on pulling the motor to make use of all that rewiring anyways?
Old Jan 1, 2002 | 08:05 AM
Engine: 4.0L
My recommendation would be leave the wire harness on the engine and remove it as one.
This is how you do it. Disconnect the computer harness and pull it back to the engine compartment (no need for disconnect now), and on the drivers side disconnect the C100 connector. That should be it. Pull the engine. the compartment is almost empty now, time for a good cleaning.
If you really want a disconnect, I can get any size for a few $$.
Old Jan 1, 2002 | 01:33 PM
92RSB4C's Avatar
Let me think this think out. Hey John, I got a chance to look at your webpage; is that flame red?
Old Jan 1, 2002 | 02:16 PM
92RSB4C's Avatar
Ok, I think I got a plan now. I'll use three connectors and put Induction and exhaust on one, Tranny and Ignition on the other, and Others on the last one.
So one the first one I'll have this:
Induction + Exhaust
T.P.S. (3 wires)
I.A.C. (4 wires)
M.A.P. (5)
I.A.T. (2)
O2 (1)
Total wires = 15
The second one would be this:
Tranny + Ignition
T.C.C. (3)
Speedo (2)
Distributor (6)
Coil (4)
Total wires = 15
The last one would be this:
Others
Oil Sender (1)
Oil Pressure(2)
Water Sender(1)
Water Temp. (2)
E.S.C. (1)
A/C (4)
A.I.R. (4)
Starter (5)
Total wires = 20
Sound like a good plan?
Old Jan 1, 2002 | 05:46 PM
92RSB4C's Avatar
Any idea where I can find those connectors?
Old Jan 1, 2002 | 06:28 PM
Engine: 4.0L
I guess, it's factory paint (1986).
Old Jan 1, 2002 | 06:51 PM
92RSB4C's Avatar
Then that's flame red. That's what I'm doing my 86 Z28 in.
Old Jan 2, 2002 | 07:47 PM
92RSB4C's Avatar
I left out a few things. I forgot to include the alternator wires and the injector wires. (18 wires) So, that's connector #4.
Old Jan 2, 2002 | 10:00 PM
Derek Samley's Avatar
injectors
the injectors should only need 3-4 wires because they should be spliced together in the harnes, because it is port fuel inj. not multiport. That should save you some conector space. Also I don't know if you should install a conector in the starter and altenator wires ther might be to much curent and would melt a normal conector.
Old Jan 3, 2002 | 08:42 AM
92RSB4C's Avatar
New Plan
Ok, so here's my new plan.
Induction + Exhaust
T.P.S. (3 wires)
I.A.C. (4 wires)
M.A.P. (5)
I.A.T. (2)
O2 (1)
Left Side Inj. (2)
Right Side Inj. (2)
Total wires = 19
Tranny + Ignition
T.C.C. (3)
Speedo (2)
Distributor (6)
Coil (4)
Total wires = 15
Others
Oil Sender (3)
Water Sender(1)
Water Temp. (2)
E.S.C. (1)
A/C (4)
A.I.R. (4)
2ND Fan Switch (1)
Total wires = 16
Old Jan 3, 2002 | 08:45 AM
92RSB4C's Avatar
SO, any ideas where I can get connectors with that many wires?
Old Jan 3, 2002 | 07:25 PM
92RSB4C's Avatar
Well, I found some connectors but they weren't the one I would have prefered, but I got them anyway. I got 2; one has 14 slots and the other has 36 slots, so that will take care of the left and right side of the engine bay. I got the right side done and now I have to finish the left side tomorrow.
Old Jan 8, 2002 | 05:02 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Do your connectors (plugs) have provisions for different guage wire? Some big 4 ga or 8 ga or 1ga? Just curious..I was looking to do something similar for stereo eqpt so I can remove everything with one plug. See ya
Old Jan 8, 2002 | 05:13 PM
92RSB4C's Avatar
No, not really. I guess you could, but it would be harder to get in the connector.
Old Jan 8, 2002 | 05:51 PM
Engine: 4.0L
A plastic connector would melt from the current those size wires are capable of. Sounds like you would need an expensive aircraft connector.
Old Jan 8, 2002 | 10:00 PM
deadbird's Avatar
Engine: TPI 305/ v6
Have you considered using a Molex connector ?
Different types of Molex connectors
Maybe I'll get it right one of these times
Old Jan 8, 2002 | 10:11 PM
92RSB4C's Avatar
That's what I used.
Old Jan 11, 2002 | 03:06 AM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
I don't think that 'crosstalk' would be a problem unless those wires were carrying lot's of and lot's of data in the equiv of around 20 or more mb's a sec. I doubt that the car's ECU transmits that kind of info.
Old Jan 11, 2002 | 10:20 AM
92RSB4C's Avatar
Hey Convert, I was just reading your kills/losses list. You should change the name Ford Explorer to Ford Exploder! LOL
Old Jan 11, 2002 | 01:25 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
theshackle
Sep 17, 2020 08:26 AM
midge54
Jan 29, 2017 07:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
