Cruise control issue
Old Sep 8, 2016 | 11:47 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Having issues out of my GTA's cruise control function....as in it doesn't function. Lol So far the underhood servo is new, the brake switch is new, and the stalk and underdash module test out good. The cruise will apparently engage once but will not re-engage once the brake is tapped or the connection is broken. I'm not working on the car myself, but has anyone ever experienced this on their car? I'd like to be able to point my mechanic in the right direction
Thanks.
Old Sep 9, 2016 | 10:09 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Cruise control issue
If you (the customer) need to point your mechanic in the right direction, I'd go ahead and find a new mechanic hahaha.
Brake switch sticking? Oops, didn't see you said that is new.
Old Sep 14, 2016 | 08:53 AM
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Just thought I might find others here who have had similar issues that might share some insight, but whatever. I'm not mechanically inclined myself, but we'll get to the bottom of it regardless.
Old Sep 15, 2016 | 05:14 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Did you replace both brake switches? Not sure which one or if both of them tie into the cruise control.
88Birdman
Oct 25, 2016 09:18 PM
BovineZro
Aug 28, 2016 06:19 PM
Looksthakill
Aug 24, 2016 04:00 PM
Looksthakill
Aug 24, 2016 01:20 PM
soul.justice
Aug 23, 2016 02:28 AM
