Stock electric speedometer-turbo 400/no speed buffer
Old Sep 11, 2016 | 08:22 PM
smh1987FFB's Avatar
Car: 1987 Formula 350 Firebird
Engine: Pontiac 400
Transmission: Turbo 400
I used a sender 4PAC from jagsthatrun.com ($104). I wired it as another person posted but found the speedometer cable drive gears in the turbo 400 made the speedometer inaccurate. Rather then change gears I found that Summit sells a universal speedometer calibration unit made by Dakota Digital (DAK-SGI-5E) for $80 that did the trick. I cut the connector to the VSS (yellow box) and wired the input from the sender to the box then used the original circuit out to the speedometer. A quick drive using any app that tracks your speed and a passenger to change the calibration and it works great.
Attached Thumbnails Stock electric speedometer-turbo 400/no speed buffer-image.jpeg
greenyone
Aug 25, 2016 05:52 PM
darren8642
Aug 19, 2016 05:31 PM
LDR
Aug 17, 2016 09:21 PM
Matt trans am
Aug 15, 2016 07:45 PM
havokjay
Aug 15, 2016 07:48 AM
