88 drivers whats up display to work
Old Sep 23, 2016 | 02:36 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so 88 digi dash gta im trying to get the wud to work so far i have the coolant working correctly f lamp and r lamp working correctly im not using the washer bottle so ill always get that on the display but i cant seem to get the trunk left door or right door to work when opening either or them how do i figure this out can someone lead me kinda in the right direction with this one
Old Sep 26, 2016 | 03:37 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 88 drivers whats up display to work
Originally Posted by soarestransam
........im not using the washer bottle so ill always get that on the display
You might be able to simply run a ground wire to the washer switch "OUT" wire,... this should shut the low washer fluid light off - at all times.
IIRC the switches for the door ajar are located on each door latch itself,... not the easiest thing to access / repair. You might also be able to use a ground wire on those circuits to shut off the lights on the display too. ( even if just for testing )
Old Oct 4, 2016 | 09:55 PM
Engine: LR4 4.8
Would anybody happen to have the oem part number for the door jam switch for 88 gta woth digi dash dont know if it is different then non digi dash ones
Old Oct 5, 2016 | 09:26 PM
Engine: LR4 4.8
So your saying the door latches have he switches built into them i recently had to get new doors cause they were rotted at the bottom another thing i dont remember seeing wires coming off the latches and traveling in the doors to the inside of the car unless u are talking about the door jam switch that turns the interior lighting on is it these you are talking about ????
Old Oct 5, 2016 | 10:47 PM
Engine: LR4 4.8
Ok so i figured it out there are 2 wires that were cut and just left hanging on the drivers side one black wire if you ground it to metal it makes the left door come on, on the wud also on the passenger side there is one black wire that was also just hanging so i touch that one to a metal ground and that made the right door ajar come up on the wud but now the only thing about it is if u close the doors they still stay lit up on wud and if i open the left door it makes the right door ajar come up so something is definitely messed up
Can someone send a diagram of the wud wiring for 87-88 gta with digi dash so i can figure this previous owner hack job wiring
Old Oct 6, 2016 | 09:41 PM
Engine: LR4 4.8
Bump where are my digi dash memberd who know this
nzwcpn
Interior Parts Wanted
Oct 11, 2016 02:34 PM
Aerothyr
Oct 6, 2016 08:46 AM
b2010
Sep 28, 2016 07:28 PM
Dracula
Sep 26, 2016 04:39 PM
