Need help identifying sensor connection, 305 TPI
Old Sep 25, 2016 | 07:49 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Hey guys,
Last night when replacing my starter which mysteriously cracked in half, I found this apparent (and broken) sensor connection. It appears to be coming from the same section of harness as the leads to the starter. I don't have access to wiring diagrams and was hoping someone could help.
The car's a '90, 305, TPI
TIA
Attached Thumbnails Need help identifying sensor connection, 305 TPI-20160924_181409.jpg
Old Sep 25, 2016 | 08:30 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Need help identifying sensor connection, 305 TPI
Looks like the knock sensor, which will be found directly in front of the starter, mounted in the drain hole at the oil pan rail.
Or, it could be to the cooling fan switch in the head, directly above the starter.
Old Sep 25, 2016 | 08:35 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
I had forgotten about the fan switch. The length seems about right, too. The knock sensor is connected and in tact, so I knew it wasn't that.
Thanks for the speedy response.
mille_3
Sep 5, 2016 09:53 PM
19irocz85
Aug 31, 2016 02:28 PM
Voltz77
Aug 29, 2016 04:20 PM
ProStreetDriver
Aug 29, 2016 12:19 PM
BovineZro
Aug 28, 2016 06:19 PM
