ignition switch
Old Jan 22, 2017 | 08:59 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
ignition switch
i'm installing my new ignition switch but the actuator rod is pointing up and the hole in the switch when mounted is pointing sideways. am i missing something obvious?
in the pic you can see the tip of the rod sticking up vertical. the view is looking straight down the steering column with the wheel dropped. i need to rotate it to the right to get it to interface with the switch.
Old Jan 25, 2017 | 09:50 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ignition switch
Iirc the rod is correct. The rod inserts into the hole on the ignition switch from the bottom not the side.
Old Jan 25, 2017 | 11:02 AM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: ignition switch
that's what i thought but i can't see where it goes....i hope i bought the right switch... i'll look again later today.
thanks!
Old Jan 25, 2017 | 06:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: ignition switch
Are you sure you don't have the switch installed backwards?
See attached.
Old Jan 25, 2017 | 07:00 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: ignition switch
i'm not sure about anything right now but the mount holes determine where it goes so i don't see how i can install it backwards. it mounts right on the very top of the column with the screws to the left. i don't see how the rod fits underneath though. didn't have a chance to look at it again today will do so in the morning. THANKS!
Old Jan 25, 2017 | 07:05 PM
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
Re: ignition switch
i think i bought the wrong switch! damn....
This part is not compatible with 1986 Pontiac Firebird Trans Am Coupe 2-Door 5.0L 305Cu. In. V8 GAS OHV Naturally Aspirated.
