Gauge cluster half working on my 87 pontiac firebird formula with a 350
I have a 87 pontiac firebird formula with the 350. My gauge cluster is only half working. The speedometer and tachometer and indicater lights work but my oil, temp, battery and now the fuel gauges arent working. I did what i probably shouldnt have but i took the cluster apart and switched the little motor things that control the needles on the cluster to see if that worked and thats when the fuel gauge stopped working. Before i did that, i changed the temp sensor and the thermostat and still nothing. Do i need a new cluster? Please help me as this is driving me nuts. Thanks charlie
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: Gauge cluster half working on my 87 pontiac firebird formula with a 350
You may have done more harm than good. Were there any conditions that caused it to be inoperative before you removed the cluster? My trouble-shooting always starts with: what was happening at the time things went haywire. So, if you can remember what you were doing with the car at that time, it will give you a starting point to work from. Another handy tool is the factory service manual (FSM) trouble shooting tables. As far as the cluster is concerned, you may need to have a shop that works on speedometers check it out. Unless of course you are confident in your abilities to assemble it back to working order.
Just the temp gauge and the oil one werethe only two that were screwed up from the start. Thats how i bought it. But now the oil is working and the volt and temp arent working
Car: '89 Firebird
Engine: 7.0L
This is odd I should know this, but it just so happens I had to trace out every damn circuit of the gauge pod this weekend in preparation for installing aftermarket gauges.
It just so happens that speedo, tach, and turns signals use the same ground trace on the printed circuit board and ground at Pin 2 of the BROWN color connector. And you guessed it.... oil, temp, volt, and fuel gauges all go to the same ground through a combination of Pin 2 and 12 of the BROWN connector.
Given your symptoms, I would guess the ground for your non-working gauges is interrupted somewhere. Check for a tear in the green sheet (circuit board), a loose connection at the connectors, and clean up the surfaces of the connectors with a pencil eraser. Also do an electrical continuity check of the wire to chassis ground. If the electrical resistance is high then the ground wire and/or connection needs to be repaired somewhere in the harness.
Car: '89 Firebird
Engine: 7.0L
Electrical connectors have a number embossed in the connector next to every electrical terminal. You'll see it on the connector itself. The electrical terminal is often called a "pin".
Qwktrip, your talking about if i have the cluster out, im looking at the back and where it plugs into the car on those copper lines? Im sorry for sounding dumb lol
Engine: 4++,350 & 305 CIs
I have had several clusters that do random weird things. Here is a good tip for a car that sits or has sat most of its life.
I take the cluster out, remove all the screws (not all at once) that are going through the circuit board for the gauge power/ground/signal terminals, use 000 steel wool on all the brass/copper contact points and esp on the brass where the electrical plug goes in the back. Carefully blow off the fine steelwool that's left.
Its amazing how accurate and how well the gauges work after that.
Ttop350, thanks for the advice, ill try it today after work. Also i have another question. On the radiator, the driver side fan stay on all the time, from the time i start the car up till i shut it off and the passenger side fan doesnt do anything. Any thoughts on this issue?
Stuck relay or ground in the ecm ? driver side
Bad fan switch, bad relay or bad fan motor. pass side
Hey qwktrip and ttop350, i just tested that i have power at the gaugs but still nothing. Do you think a new gauge cluster would fix the problem?
Car: '89 Firebird
Engine: 7.0L
The only thing common with the gauges you mention is the grounds. If you had a power problem then it would affect all the gauges.
Hey qwktrip, how many of those pins behind the cluster should be getting power? I have one from the upper plug and one from the lower plug that is getting power.
Car: '89 Firebird
Engine: 7.0L
I think this is what you're seeking. This is for '88.... can't guarantee it is the same for your '87. It is all I could find, and I felt lucky even finding that!
C1 is the BROWN connector (lower), and C2 is the GREY connector (upper)
https://www.thirdgen.org/forums/elec...ml#post6110270
