02 sensor
Old Mar 3, 2017 | 08:27 PM
eyeroc87's Avatar
Car: 1987 IROC
Engine: 5.7 TPI
Axle/Gears: 9 bolt 3.27s
02 sensor
I wired up my 3 wire heated 02 sensor like it said here, and now im blowing the ecm fuse and wont start, its wired into A/C fuse cause its been removed. ant help? thanks
Old Mar 3, 2017 | 11:11 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 02 sensor
Post a link to the wiring instructions/schematic you followed.
Old Mar 4, 2017 | 09:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 02 sensor
the heating element power wire can go to the grey wire on the fuel pump relay or to the acc power of the esc module pink/blk.
Old Mar 6, 2017 | 03:28 PM
eyeroc87's Avatar
Car: 1987 IROC
Engine: 5.7 TPI
Re: 02 sensor
I don't think I under stand, I wired one black to a switched ign ony,,i used a/c fuse for switched power since there is no A/C, one black wire ground on body, black wires off 02 and the blue off 02 to computer, purple wire. what id do wrong, I didn't mess with fuel pump relay.
Old Mar 6, 2017 | 08:12 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Re: 02 sensor
Unless there's something funky going on with your 12v (key on) source, I'd guess that there's something wrong with your O2 sensor if the fuse is blowing.
Again, post a link to the wiring instructions/schematic you followed.
Old Mar 6, 2017 | 08:41 PM
eyeroc87's Avatar
Car: 1987 IROC
Engine: 5.7 TPI
Re: 02 sensor
ok . found the link with the diagram, it wasnt this site, but sethsthirdgen, but all concure that one blk wire was hot and one blk was ground. blue/purple was computer. 02 sensor is acdelco AFS74 from Rockauto. I beginning to think maybe this is something else. but all started when I wired up 02. it was a daily right up to this.
Old Mar 10, 2017 | 08:37 PM
hockeyman48's Avatar
Re: 02 sensor
May be bad heating element in O2.May be shorted to ground internally in O2. I would check resistance of element leads (black wires). Sorry... don't have an ohm value range ..but you probably can research that and get its value.I would also meter both black wires to see if one black wire is already grounded internally as it may be polarity sensitive, meaning you can try switching black wires.
Old Mar 12, 2017 | 04:48 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Re: 02 sensor
You can mix and match (figure of speech) the two common colored wires; they're not polarity sensitive.
