Serpintine conversion ac wiring
Old Mar 13, 2017 | 09:37 PM
snake 309's Avatar
I'm in need of some help, I did a serpintine conversion on my 85 camaro. I'm looking to hook up the Ac compresser wiring and my original compresser had one double wire plug (as shown in picture 1) and the new compresser has two double wire plugs (shown in the 2nd picture) how do I wire the new compressor to work with my old wiring? Or do I need to swap clutches and use my old compressor?
I'm also installing a electric fan and would like the fan to turn on when the compresser starts. I will be installing a fan controller to turn the fan on when it hits 160. Any help would be great!
Old Mar 13, 2017 | 11:02 PM
Drew's Avatar
Re: Serpintine conversion ac wiring
The switch on the back of the compressor is the high pressure cut-off switch. If your old compressor doesn't have the switch, your car doesn't need it. The compressor wiring is different in different years and with different engines. You're probably furthest ahead to wire it to match what you had before, since the rest of the wiring in your car is matched to that system.
Old Mar 14, 2017 | 05:47 AM
snake 309's Avatar
Awesome thank you, I will just splice in that front plug to my original wiring
