Rear Hatch Motor Housing
Old May 6, 2017 | 07:14 PM
jeremyb1988's Avatar
On Probation
Car: 1987 IROC-Z Camaro
Transmission: T-5 5 Speed
Hey guys...okay so I fixed my rear hatch problem today finally. I bought the car about a month ago...and once I started taking apart the panels I noticed someone had ripped out the relay (not the harness). I had ordered a what was listed as ORIGINAL fit motor and housing from HAWK motorsports. Well low and behold the housing WOULD NOT FIT. Anyways...I went to Camaro Central and paid an arm and a leg for a rebuilt/used hatch assembly. Now it works fine. Question are two things. Do you guys know of ANY place that sells original fit housing for those just incase I need one...the one from Camaro central has cracks in the screw areas...but like I said works. I looked at 1AAUTO https://www.1aauto.com/trunk-lid-pul...=202527&y=1987 and they looked like they had one. Also...if your trying to really baby the latch is it best to gently let the hatch down and manually kinda push it down until the old girl starts her motor and pulls it down ??? Thanks guys
Old May 7, 2017 | 06:53 AM
Drew's Avatar
Re: Rear Hatch Motor Housing
Dorman offers the housing, also TDS http://top-downsolutions.com/ etc.
Most pulldowns get damaged by people slamming the hatch, or letting the lift supports get so bad the hatch slams. By design it's a soft close hatch. It's not babying it, just push the hatch closed and push down lightly until it clicks and starts moving down.
Old May 7, 2017 | 10:01 AM
On Probation
Thanks Drew...well the car has been really taken care off...it seems to work great...the housing has some little cracks along the screw insert areas...any reason for concern there or should it last me quite a while? I was kinda upset Camaro Central would send out one to me with cracks like that...
Old May 8, 2017 | 01:42 PM
Drew's Avatar
Was it used? Most of the time the plastic housing will be cracked around the screws. Over time the chemicals in the plastic will leach out, and the plastic gets brittle. Even just the pressure of the screws torqued into the plastic usually causes them to get stress cracks. Nature of the beast. Fortunately they tend to stay together as long as you're careful about closing the trunk.
Old May 9, 2017 | 01:42 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
l would recommend getting the reinforced housing/ rebuild kit from TDS
http://www.top-downsolutions.com/hatch-pull-down-items
