145mph Speedo wont go over 79mph
Old Jun 12, 2017 | 09:46 AM
LS2Swapped92's Avatar
Original one worked fine (RS cluster)
145mph one wont go over 79mph, just stops until I slow down and it climbs down normally 79 and below
Anyway to test / fix this to ensure it's not the car? IIRC it expects to see 4,000 PPM?
Old Jun 13, 2017 | 04:29 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
Re: 145mph Speedo wont go over 79mph
have you tried swapping the circuit boards? does your tach work correctly?
Old Jun 19, 2017 | 10:18 PM
Everything works properly, even the speedo up until 79
Can I swap circuit boards with a 110?
