Fuel, Volts, Temp gauges not working
Old Jun 27, 2017 | 07:46 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I had my alternator out and ever since I put it back in, my fuel gauge is all over the place. Reads empty, then past full and sometimes slowly moving in between. My volts read about 9 and the temp just sits at 40. I checked the actual voltage and it's fine. This all happened after the alt went back in. Wondering what the commonality is?
Old Jul 3, 2017 | 01:49 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
On The Edge
You didn’t mention the model and year so this info is generic.
If you have a normal (non digital) dash there’s no way R&R’ing the alt can damage the instruments.
Even reversing the polarity can’t.
If it’s a digital dash then that weakens the system.
If you have a normal (non digital) dash the most likely cause of the problem is a bad ground.
Squeeze behind the dash, make sure the connectors are tight and use an ohmmeter to make sure the grounds are making good contact.
Happy Racing !
He Must Have Been Cheating - Because I Was And He Almost Beat Me.
