Pick up coil interchangeability
Old Jul 9, 2017 | 11:58 AM
peppersteak's Avatar
Can i use the pick up coil from a 229 even fire chevy v6 in a sbc v8 non-ccc dizzy? That is, of course, swapping the pick up coil only and keeping the v8 pole piece.
thanks for the input
Old Jul 9, 2017 | 01:19 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Pick up coil interchangeability
Do a part number search on rockauto.com to see if both applications use the same pu coil.
Old Jul 9, 2017 | 01:20 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I don't know.
If you start by checking a PN for the application that uses the 229 (G-body) and the PN for the SBC application, that might be a hint.
Also, Hollanders interchange books, used by salvage yards are helpful; they may have an online version to try.
Old Jul 9, 2017 | 03:33 PM
it seems every auto parts store sell the pick up coil and the pole piece as a unit. I just tried and the v8 seems to run fine with the v6 po coil. We'll see. Thanks guys
