starter "clicks" but no start
Car: 1990 Camaro RS 5-speed
Engine: 305 TBI
Hi everyone after sitting for a while, when I'd go to start my car it would turn over very slowly like the battery was dead. After awhile that turned into just rapid clicks coming from the starter. I replaced the starter and cleaned the battery posts and everything i could find, but even with the new starter I still just get clicks. However if I jump the starter with a screwdriver it works fine. Any help would be awesome!
p.s. the car is a 90 Rs with a 305 tbi and 5-speed
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Re: starter "clicks" but no start
Check to see what your voltage is on s terminal when cranking since you can jump it between other terminals. Assuming that's the limiting voltage you can next look at the ign switch and clutch safety switch voltages when cranking
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
I ended up installing a secondary relay in my '91. easy peasy, no more problems with low voltage on the purple wire..
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
From the ign switch iirc power runs through park neutral switch to the starter enable relay. The issue might be at the switch or relay.
Engine: Lb9
Transmission: M20
