Wiring switch to radiator fan
Old Jul 29, 2017 | 10:51 PM
LGS_18's Avatar
Car: 1992 Firebird
Engine: 3.1 6 cylinder
Transmission: 700R4 automatic 4 speed
i have a 92 bird with the 3.1. Trying to wire a switch to the fan and because the fan comes on 225 and i want it to come on earlier. I cant seem to wire it directly to the relay for the fan to come on. Any suggestions?
Old Jul 30, 2017 | 12:20 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Wiring switch to radiator fan
You must be wiring it wrong. I don't have schematics for your car but the relay might be switch to ground.
Old Jul 30, 2017 | 03:19 PM
LGS_18's Avatar
Car: 1992 Firebird
I wired every way i could. Im ASE certified for electrical and im lost. Lol
Old Jul 30, 2017 | 03:29 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
In that case, are you sure you are on the correct relay?
Sounds like all you really need are the schematics and you are good to go. Guessing you have access to that at work.
Old Jul 30, 2017 | 04:36 PM
LGS_18's Avatar
Car: 1992 Firebird
Yes, i have the correct relay because i just changed it last month because the fan wasnt working. I think its something with the fan because connecting a direct current should make the fan kick on.
Old Jul 31, 2017 | 02:18 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The green with white stripe wire to the fan relay gets grounded, tripping the relay and turning on the fan. You can make that happen in a number of ways
providing that THE FAN WORKS
Old Jul 31, 2017 | 02:29 PM
LGS_18's Avatar
Car: 1992 Firebird
i tried so many ways and i dont know why it wont work. The fan does work.
Old Jul 31, 2017 | 02:30 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Old Jul 31, 2017 | 02:42 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
That is, grounding the wire with the key on will actuate the fan IF all other wiring is intact
Old Jul 31, 2017 | 04:52 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wire Mire
On the fan relay there is a dark green wire with a White stripe.
Connect a wire to that point and run it to a switch in the cockpit.
Connect the other side of the switch to ground.
If that doesn’t fix it the PO probably altered the wiring, in that case you can let us know.
Happy Racing !
Nitromethane Smells Sweet When Burning, But Please, No Roasting Marshmallows On The Zoomies
Old Aug 3, 2017 | 04:47 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
Here is my setup. Not perfect but functional. Splices into green/ white, then goes in trough firewall, then switch, and then back into firewall, then into that grounded bolt. Not sure if that's a good ground, but it works.
Attached Thumbnails Wiring switch to radiator fan-imag0247.jpg   Wiring switch to radiator fan-imag0246.jpg   Wiring switch to radiator fan-imag0245.jpg
Old Aug 3, 2017 | 04:54 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
heres how its set up
