Wiring switch to radiator fan
Old Jul 29, 2017 | 11:34 PM
LGS_18's Avatar
Car: 1992 Firebird
Engine: 3.1 6 cylinder
Transmission: 700R4 automatic 4 speed
i have a 92 bird with the 3.1. Trying to wire a switch to the fan and because the fan comes on 225 and i want it to come on earlier. I cant seem to wire it directly to the relay for the fan to come on. Any suggestions?
Old Jul 31, 2017 | 05:17 PM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Re: Wiring switch to radiator fan
You can try an adjustable fan controller they cost around $30 I have one on my bird works good.
Old Jul 31, 2017 | 06:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You can also have your memcal (computer chip) reprogrammed to lower the on and off temps.
Old Aug 3, 2017 | 04:01 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
my fan does not work by itself. it should come on with the a/c but it doesn't. I do know that when the green/ white wire for the relay is grounded the fan will kick in. I'm sure its my cts but idk where its at. so I just added a switch to ground that wire.
