88 GTA Vats Bypass
Car: 1986 Trans Am
88 GTA Vats Bypass
I've done a lot of searches and have read extensively on this, but am still having issues. I boughts the Bakers Electronix DFVATS Bypass Module which has the standard signal out as well as the 30Hz signal out seeing as I wasnt sure which I needed. I am unclear as where to install this module, does anyone have any insight on this? Also do I still need to do that starter relay bypass with this module? If so, I'm having problems there as well. I looked behind the panel on the drivers side as well as up and around the fuse box, I can not find it anywhere. The car is a 1988 GTA 5.7L TPI Automatic. Also has the digital dash if that makes any difference.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88 GTA Vats Bypass
The starter enable relay needs to be bypassed. The module can be mounted bye the ecm.
Pin b6 of the ecm dark blue wire is vats hz input.
Engine: Lb9
Transmission: M20
Post #3
https://www.thirdgen.org/forums/elec...ing-tuned.html
For the bakers box a6 at the ecm bnk/blk is switched power. A12 blk/white is a ground.
Engine: Lb9
Transmission: M20
I have allways seen the relay on the drivers side under the kick panel.
Sometimes under a piece of tar tape.
Or tucked up in the loom bye the fuse box last post pic.
https://www.thirdgen.org/forums/tech...ont-start.html
Last edited by Tuned Performance; Aug 4, 2017 at 04:31 PM. Reason: More information
Car: 1986 Trans Am
Car: 1986 Trans Am
Found it and did the starter relay bypass. Had to removed what ended up being a grocery back full of wires that did not belong nor was very professional looking. The relay was tucked way the hell up in the dash.
