Starting problems
Old Sep 25, 2017 | 05:04 AM
scottstell's Avatar
Starting problems
When I turn the key the car starts to fire but when I let go of the key it stalls. Any ideas? 91 3.1
Old Sep 25, 2017 | 01:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Starting problems
Sounds like a mis adjusted or faulty ignition switch
Old Sep 25, 2017 | 07:18 PM
scottstell's Avatar
Is there a way to test it to find out it is bad?
Old Sep 25, 2017 | 07:24 PM
Engine: Lb9
Transmission: M20
Hooking up a vom to the ign wire would show if its hot. The switch is kinda hard to access without dropping the column.
It should be similar to this
Old Sep 29, 2017 | 08:20 PM
scottstell's Avatar
Thanks I'll check it out.
Oenone
Sep 30, 2016 08:47 AM
BovineZro
Sep 26, 2016 04:53 PM
gta_knight
Sep 26, 2016 04:45 PM
dr.watkins9
Sep 22, 2016 03:33 PM
firebirdta84
Sep 20, 2016 01:06 PM
