84 Z28 headlights...
Old Sep 29, 2017 | 11:49 PM
MSDinoia's Avatar
84 z28, changed spark plugs to the new e3s, turned on the car after done lost head lights, cig lighter, radio, rear hatch release.
Old Sep 29, 2017 | 11:53 PM
MSDinoia's Avatar
Re: 84 Z28 headlights...
What blew or burnt out?
Old Oct 2, 2017 | 06:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
So Much Spark It Melted Accessories For Miles Around!
While you were changing plugs you accidentally created a short and blew a fusible link.
You can use a voltmeter to find the blown one.
Fusible Links usually look like a one inch plastic rod in line with the wire and are located near the battery or at the starter.
Using a test light
(the type for testing for voltage, not a continuity tester) probe both sides (one side at a time) of the ACC fuse.
If there is power both sides, the problem is a bad connection from the fuse output to the items you mentioned, and the problem is near the fuse block.
If there is NO power both sides, the problem is a bad fusible link near the battery, or the wire going to it.
Happy Racing !
If Your Engine Blows Up Over The 1,000’ Mark You’ll Know It Was Built Perfectly
Old Oct 3, 2017 | 07:27 AM
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
accessory fuse.
Old Oct 9, 2017 | 06:02 PM
NINÅ's Avatar
Transmission: 765R4
The ACC fuse has nothing to do with the headlights.
We told him about the ACC fuse in case after replacing the link which will restore the headlights, he has no ACC’s, to test that fuse.
Happy Racing !
My Brakes Don’t Work AT ALL When The Car Is In The Air
Old Oct 13, 2017 | 08:31 PM
MSDinoia's Avatar
After trying to find diagrams and what not of fuses modules and what not and after today finding nothing I did think about the fusible link. I had a Dodge Dakota back a 96, couple years later just died while driving. My mechanic at the time told me it was the fusible link. Made me think. So, this should be near the battery, Yes? thanks you guys
Old Oct 13, 2017 | 08:34 PM
MSDinoia's Avatar
I also lost the cooling fan, will not go on when engine gets hot but will go on if I turn on the AC. I was told to replace the switch, didn't work. Still no fan.
Old Oct 14, 2017 | 12:58 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Did you replace the right switch? It's on the passenger side between the last two plugs. The fact that AC on turns on the fan shows that the fan and relay are good. Could be a wiring issue? If you take the green with white stripe wire off the fan switch and ground it with the key on, does the fan now operate? If not trace that wire back to the relay and insure that you have a good
connection. If the fan works it's the switch.
What temp are you reaching when it's not going on? The stock switch doesn't turn on the fan until 238 degrees or so. Did it work before this?
Old Oct 15, 2017 | 10:03 AM
MSDinoia's Avatar
it will over heat in 10 mins with car in park. I did the fusible link yesterday and everything is back on, but the elec.door locks want to lock and unlock about every 30 seconds or so, even when the car is off. those buttons will not control them at all. I was actually looking for the link to see how "fun" it would be to get at and change,only to find I forgot it when reconnecting the wires back to the starter that wire touched the positve lead to the starter and I heard the locks try to lock. I disconnected to battery and reconnected that wire and everything came back on. today I am just going to unplug the power to those "motors" so I don't have to keep removing the fuse when I am not in the car.
Old Oct 15, 2017 | 10:09 AM
MSDinoia's Avatar
the fan switch I replaced for the fan was on the driver side, was directed to it from an automotive store chat online, was given link to that page where I then bought it. this is 84 z28.
Old Oct 15, 2017 | 12:07 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
sounds like you replaced the sender for the temp gauge. Do you have a sensor looking thing in the same spot on the passenger side head? It would be between the last two plugs. That is the fan switch. Do that test with grounding the wire with key on. What happens?
Old Oct 17, 2017 | 01:40 AM
MSDinoia's Avatar
I want to say thanks to those that have helped me. My huge issue I need to resolve is she is sucking gas like crazy. Would this me a carb issue? The float, the bober that plugs the hole where the gas enters the carb. I need to get the timing adjusted. when I start it hot it runs 5000 rpms or lower and sometimes will stall. Back to the carb, been going though a tankful in about 60 mi.
Old Oct 17, 2017 | 06:40 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Are you sure your sending unit in the fuel tank is working correctly? Because burning 15ish gallons in 60 miles would mean 4 miles per gallon. . . . .
I would get your timing right first, then worry about all the other issues. Make a list and systematically work through it.
I would get rid of the electric fan and put the stock fan and clutch back on it, they're simple and they work.
Old Oct 17, 2017 | 12:33 PM
MSDinoia's Avatar
Hi, I guess I will have someone check the timing asap and then the sending unit, everything underneath the hood is original except for an engine rebuild back in 99. So, you don't think it would be anything involving the carb?
Old Oct 17, 2017 | 01:53 PM
Car: 1983 Z28
Could totally be something with the Carb, I would just troubleshoot the electronics first since they are finicky.
i.e. if when you fill up you know you're putting 15 gallons in each time then you know your sending unit is fine, check that off the list.
Those came from the factory with a clutch fan, sounds like someone put the electric in with the rebuild.
Old Oct 18, 2017 | 01:39 AM
MSDinoia's Avatar
The clutch fan wasn't changed when the engine was rebuilt, I may have done it years ago, can't remember that far back. I will try to make an appointment for Friday to get the sending unit and the timing checked.
slimwhitman
Convertibles
163
Aug 24, 2025 10:56 AM
jeff91z28/l98
Dec 22, 2016 05:07 PM
RocketGirl
Oct 3, 2016 06:30 PM
hacker383sc
Exterior Parts for Sale
Sep 22, 2016 07:11 PM
1987L69
Sep 21, 2016 10:02 AM
