Ignition Switch relay location?
Old Oct 3, 2017 | 03:08 PM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Anyone know where there ignition switch relay is located on the 89 IROC 5.7L?
Old Oct 3, 2017 | 03:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ignition Switch relay location?
What’s a ignition switch relay ?
Old Oct 3, 2017 | 03:41 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
What actual problem are you trying tp fix?
Old Oct 3, 2017 | 03:49 PM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
My bad....nevermind....I am confusing things on different cars. Sorry for the bad post!
Old Oct 3, 2017 | 03:56 PM
Engine: Lb9
Transmission: M20
Are you still having cranking issues ?
https://www.thirdgen.org/forums/elec...ent-relay.html
Old Oct 6, 2017 | 10:40 AM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Yes, still troubleshooting this problem. I am going to have to take a look at the ignition switch next. I understand it is located on the top side of the steering column and I need to drop the column down to get access to it. In the pic, there is a bracket holding up the column. Looks like I have to take out the four bolts (two on each side) and then undo the two nuts (one on each side) to get the bracket off. Is that right? Question....do I have to then prop up the column somehow? Will it only drop a certain amount after the bracket is removed?
Old Oct 6, 2017 | 10:49 AM
Engine: Lb9
Transmission: M20
Remove the two nuts on the column mounting bracket. There is also 3 bolts iirc holding the flange to the firewall.
Motown
Nov 20, 2016 01:19 PM
W72
Mar 10, 2007 08:34 PM
