Neat, Cheap, little USB Charger install.
Was gonna put this in the lighter port, but it didnt fit.So into the ashtray, (something else i dont use), but not willing to give it up either.Has a cool little digi volt display, (wired key on for obvious reasons).
Not digging the mounting from the top.I redid it for a flush look.Ready for repaint.
Cut out the rusted section.Made/welded a bracket.Secure USB w/ two small screws (hole/s).That is all.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Neat, Cheap, little USB Charger install.
I did similar, but I was able to hog out the hole in the plate to mount the port in the stock cigerette hole
Car: 92 Firebird
Engine: 4.8 LR4
Stealth? Doesn't get more stealthy than putting it in there lower. You can't even tell it's changed when you open the door
