Headlight wiggles when turned on
Old Nov 15, 2017 | 04:37 PM
Napster134's Avatar
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Hi all,
I have a weird problem with my headlights that I can't seem to find any info on when searching. Maybe my search terms are wrong but I've tried a few and can't find much so hoping someone can help me out here:
Car is a 91 Ponitac Firebird with the original pop up headlights/motors.
I turn on my headlights and they both go up. As soon as they reach their travel distance and are fully UP then one of them starts to wiggle / stutter. It's hard to explain so here's a video:
As you can see, it eventually stop wiggling and feels solid, however, after driving for some time it will start to slowly come down on it's own to the point where I need to flip the headlight switch on/off again to re-raise the headlight. When I do this, it will do the wiggle thing again and stay up for another interval of time...
Not sure what could be causing this problem. Any ideas?
Thank you!
Old Nov 15, 2017 | 04:49 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Headlight wiggles when turned on
"wiggles when turned on"
I had a girlfriend like that once.
I've read a lot of threads on here about inop. headlamp motors of one type or another. This symptom is a new one to me. But I would not be surprised it it gets down to being "the usual suspects"...the plastic bushings.
Old Nov 15, 2017 | 04:51 PM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
LOL...
Probably why I couldn't find that term in my search...
Anyhow, the plastic bushings... where can I get some new ones? Are they pretty easy to replace?
Old Nov 15, 2017 | 06:23 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
[QUOTE=DynoDave43;6183463]"wiggles when turned on"
Good One Dave.
Old Dec 13, 2017 | 01:21 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Well, since Dave's situation probably did not cause a performance problem for him, I will just address the OP's headlight problem, for which I might have an answer. And if it's what I think it might be, then it will be an easy fix. But describing how to fix it might not be easy.
Assuming you've checked the four body bolts that secure the bucket assembly to the frame, and they are tight; and that the bolt that secures the motor is tight; then there is a small oddly-shaped nut that secures the motor's arm that actually raises and lowers the headight, and it could be loose. But IIRC, the entire assembly had to be removed to be able to access and tighten the nut.
Sorry for the vague description, but without pics, it's not easy to describe.
Old Dec 13, 2017 | 06:37 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Ahhhh, I remember the wiggly girlfriend years..
http://www.top-downsolutions.com/hea...ght-repair-kit
Old Dec 13, 2017 | 07:00 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yeah...umm wiggles, shudders, quivers......Its the bushings. Ya got knock the bushings outta her and replace em.
Old Dec 13, 2017 | 07:02 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You made my day, Dave!
Old Dec 13, 2017 | 12:25 PM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
LOL...
Ok! UPDATE!...
It was the bushings! Knocked them out and a bunch of white crumbled cheese looking stuff came out... Put in brand new gears/bushings from a vette and everything's back to normal!
Old Dec 13, 2017 | 01:42 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Good deal.
Yeah, you really gotta watch out these days for that cheesy like substance.....could be a bad situation.....
Old Dec 13, 2017 | 05:09 PM
DynoDave43's Avatar
Glad you got it fixed Napster134.
Old Dec 16, 2017 | 09:57 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
This thread made me laugh
