87 GTA Cruise Control Issue
Car: 1987 GTA Vert
Axle/Gears: ?
Hey Guys,
So i have finally got to the point where I need some advice, about a year ago i replaced my turn signal switch in my TA, and the wipers work, etc, however now the cruise control is not working. Would anyone have any ideas on maybe were to start to troubleshoot something like that?
Thanks in advance.
Steve
Thanks in advance.
Steve
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 87 GTA Cruise Control Issue
Have you looked at the vacuum lines to make sure they are hooked up ?
https://www.thirdgen.org/forums/tech...seem-find.html
https://www.thirdgen.org/forums/tpi/...t-working.html
I’m not sure if this is the same as your car but here’s a schematic of the cruise
http://www.austinthirdgen.org/mkport...se_control.jpg
Getting a fsm would be ideal, not sure if you need this or a electrical one.
https://m.ebay.com/itm/1987-Pontiac-...709?nav=SEARCH
Car: 1987 GTA Vert
Axle/Gears: ?
Yep the wire is plugged in and i actually replaced the servo and verified all the lines were plugged back in to where they should be,
I do have the FSM and have been scouring through that, But ill check out the links above as that may save me some time. I appreciate the help!
Notplayn
Jul 4, 2013 12:02 AM
mmadden55
Oct 21, 2009 06:17 PM
89ProchargedROC
Feb 19, 2003 07:48 PM
