Fuel gauge saga
Car: 1984 Z28
Transmission: TH350
Fuel gauge saga
Having problems with my fuel gauge in my 84 Z28. Finally got around to dropping the tank and testing the sending unit which tested as good. The gauge in the instrument cluster still reads way past full. Is there a way to go around the wiring? I tried running a separate black wire from the pug at the tank with no luck. Or do I need to start tracing the harness and checking for breaks?
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: Fuel gauge saga
Not sure if this is your problem, but it's worth a look if your sending unit tests ok. When I had the original gauge cluster in my 85Z, the fuel gauge one day would not come off full, after I filled the tank. Turned out that the needle had somehow jumped over the stop, and was stuck there. A hard tap on the plastic panel fixed it. Have a look at that. You may need a magnifying glass, to see if it is stuck.
Alicat.
Alicat.
Car: 1984 Z28
Transmission: TH350
Re: Fuel gauge saga
As of yesterday the gauge is working! Posting here in case someone has a similar problem. One of the contacts where the wiring harness plugs into the instrument cluster had gotten pushed back somehow and wasn't making contact.
Re: Fuel gauge saga
Hello all! My gas gauge is sitting on empty on my 88 TA and the tank is full. The only time the needle moves is when I unplug the sending unit from under the car then it moves to past full. I have checked out all the wiring and found nothing wrong. Any help on what it can be? Thanks.
Car: 1984 Z28
Transmission: TH350
Re: Fuel gauge saga
I would check the sending unit, see what the ohms are. Here is a link with a general how to: https://itstillruns.com/check-fuel-s...t-5050371.html
My Camaro was a 0-90 ohm sender, not sure if a TA is the same.
Car: 1984 Z28
Transmission: TH350
Re: Fuel gauge saga
It might be possible to check the ohm readings with if you can get to the wires. There should be a certain reading when full, verse half full or empty.
Car: 1984 Z28
Transmission: TH350
Re: Fuel gauge saga
I'm not sure it would work, just an idea but there should be a certain ohm reading when the tank is full vs empty. At full it should read 90 ohms if I remember correctly. Then at or near empty the reading should be getting closer to 0 ohms. It might be something to try before dropping the tank. There might be some more info on this in one of the forums.
Jim85IROC
Jul 20, 2001 07:07 PM
