1992 camaro speedometer
Old Apr 4, 2018 | 05:25 PM
Dave Keefer's Avatar
Car: 1986 iroc Camaro
Transmission: Manual TKX
Axle/Gears: 370
Hi Guys , looking for some help . The speedo on my 92 camaro works intermittently . It works most of the time and seems to be accurate however sometimes it stops working and then will come back on after a while. Is there a speedometer cable? Is there a fix for this ? Must I send out my computer or what the heck is the problem. Love the car and have no problems getting it fixed if someone can tell me what it is. Thanks
Old Apr 4, 2018 | 06:37 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 1992 camaro speedometer
Hi Lisa ,
There is no cable , it's an all electronic speedometer that has a "VSS" (vehicle speed sensor) at the transmission's tailshaft (where a cable would have attached , back in the day) that sends a signal to the dash mounted gauge through a "VSS buffer" (which appears to be in different places depending on model year) .
here's a handy little schematic that covers your 1992's speedometer ....
Thank You Tuned Performance and I have corrected my post per your info .
Old Apr 4, 2018 | 06:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The above schematic doesn’t show the vss buffer but it’s in the ecm.
https://www.thirdgen.org/forums/inte...meter-not.html
Old Apr 6, 2018 | 08:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For a '90 - '92 f-body this is only true for a VIN T, F or 8. VIN E vehicles have a 4-Out Buffer box under the dash.
RBob.
Armored91Camaro
Jul 23, 2024 12:58 AM
rarebmx
Apr 14, 2015 06:27 PM
Fermin91rs305
Sep 25, 2011 08:36 PM
mach158
Jun 28, 2002 08:30 AM
