Harness questions
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Harness questions
Iirc 88 has the alternator on the drivers side. There are length differences between birds and Camaros since the battery and ccp are on the passengers side.
You might consider doing the 870 to 165 repin and addition of relays.
It's going to get more complicated the further you go from the same year and options, like 88 would use a different wiper motor, things you dont normally think about... To do it right, you'll either be splicing parts of your old harness into a later harness, or changing parts to match the later harness's donor car.
Engine: Lb9
Transmission: M20
http://f-body383.tripod.com/AAB/870-...pRepinning.htm
Information on the ecm swap
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
the other one was for the tuneport
'88 was one piece, everything in one harness.
None of those interchange, but like Drew said, you can splice things together.
Engine: Lb9
Transmission: M20
You might want to double check c100 for differences before you plug it in.
http://www.austinthirdgen.org/?pid=19
michael
17
Jun 25, 2015 08:36 PM
