Help! I have a Wiring conection problems.
Old Apr 13, 2018 | 05:27 PM
Norcha's Avatar
Hello everyone, I'm a rokie. In February of this year, I got to one of my dream cars-Firebird(Yrans AM 1985). I disrupted the car interior, made body inspection and sound insulation. After improvements, it takes aprox, month, putting together the instrument panel I can't find some wire conections. Maybe someone can help in this matter? Thank you in advance.
Attached Thumbnails Help! I have a Wiring conection problems.-img_8292.jpg   Help! I have a Wiring conection problems.-img_8291.jpg   Help! I have a Wiring conection problems.-img_8290.jpg   Help! I have a Wiring conection problems.-img_8289.jpg   Help! I have a Wiring conection problems.-img_8287.jpg
Old Apr 13, 2018 | 05:31 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help! I have a Wiring conection problems.
The second to the last looks like cruise control
The bottom looks like neutral safety switch.
Old Apr 13, 2018 | 08:12 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/inte...mn-wiring.html
Old Apr 13, 2018 | 08:23 PM
OrangeBird's Avatar
Car: 1989 Firebird
I agree with TP , Image 8289 plugs into Image 8291 and is for the cruise control switch located on the turn signal lever . Weird looking plug , that's for sure .
Old Apr 14, 2018 | 01:52 AM
Drew's Avatar
Purple and Yellow screams neutral safety switch. The other un-identified looks like the type that plugs in the fuse block.
FWIW its not unusual to have extra unused wires for options a car doesn't have.
Old Apr 14, 2018 | 02:35 AM
Norcha's Avatar
Thank you very much for the useful information. Where is neutral safety switch location? Image 8287 (purple and yelow-black conector)
Old Apr 14, 2018 | 02:45 AM
Norcha's Avatar
Image 8292 (black wire with black conector) I chek the plugs in the fuse block, I don't find some similar conector and can't put it in fuse block.
Old Apr 14, 2018 | 05:46 AM
6998poncho's Avatar
Car: 1998 Firebird Formula M6
Engine: LS6 installation finished 8-17-2011
Axle/Gears: Stock 3.42 Ratio
Typically the neutral safety switch is on top of the steering column near the base at the floor. That's where you find it on older cars and I can't remember if that's still the location on 3d gens.
Old Apr 14, 2018 | 09:44 AM
Drew's Avatar
Look on the clutch pedal.
Jk_Under
Jan 6, 2013 06:46 AM
Erick
Jun 29, 2007 10:17 AM
fastvetteTPI84
Aug 18, 2002 05:38 PM
Fastbird
Oct 19, 2000 03:26 PM
