what will it take to use the cruise
Old Jan 5, 2002 | 08:57 PM
AustinT's Avatar
89 camaro
It had a 305 TBI with a t5
Now it has zz430 with a Holley Carb and a t56. What Do I need to do to use the stock Cruise Control?
Old Jan 6, 2002 | 09:33 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
The cable from the module to the throttle bracket needs to be hooked up.The vacuum line from the cruise module also. Make sure there is a switch for the clutch pedal that shuts off the cruise control when you depress the clutch. And doucle check the harness and wiring is still there and all plugged in from the motor swap.That's all I can think of from the top of my head.
Old Jan 6, 2002 | 01:01 PM
AustinT's Avatar
Thanks RSpeed.
What tells the Cruise what speed the vehicle is at?
Old Jan 6, 2002 | 10:24 PM
RSpeed's Avatar
The VSS wire.
Old Jan 7, 2002 | 08:14 PM
AustinT's Avatar
Vss Is on the back of the speedometer Right?
Old Jan 7, 2002 | 11:57 PM
RSpeed's Avatar
On your car,it comes from the tranny and goes to the computer.Since yours is cable driven,the VSS wouldn't go to the gauge cluster if I'm not mistaken.I can't remember the color for the wire though.I'll see if I can find out for you tomorrow.
Old Jan 11, 2002 | 12:42 PM
AustinT's Avatar
Any body know the color of the vss wire
Do I really have to mess with the Vss wire? Wouldent the cruise work just fine If I bought A cable X to drive the speedometer with the signal of the T56. Correct me please if my thinking is all wrong.
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
ULTM8Z
Sep 16, 2015 09:15 AM
