need ignition + for heated o2 sensor
Subscribe
May 10, 2018 | 11:38 AM
is there a empty cable in the engine bay or where is the best source for a ign+
thanks a lot
Reply 0
May 10, 2018 | 12:15 PM
Mount a relay connected to the positive battery terminal and switch it over using the Pink/Black wire from the ignition switch (12v Ignition).
Reply 0
May 10, 2018 | 01:27 PM
Re: need ignition + for heated o2 sensor
You can tie into the fuel pump relay. The o2 only draws half a amp no need for a dedicated relay.
Reply 0
May 10, 2018 | 06:30 PM
Quote:
fuel pump relay
^^^ This ^^^
It is the CORRECT way. As opposed to, the "alternate ethnicity of your choice engineering" way.
Reply 0
May 10, 2018 | 07:11 PM
I did this when I installed my SLP headers and no issues have appeared.
Reply 0
May 10, 2018 | 07:12 PM
Quote: You can tie into the fuel pump relay. The o2 only draws half a amp no need for a dedicated relay.
I did this to my car. No problems after several years.
Reply 0
Subscribe
