Do I need a heated O2 sensor?
Old May 24, 2001 | 08:15 PM
Jester's Avatar
I have an open 4" exaust after my turbos, where my sensor is, so no backpressure pretty much.
I only use it for an A/F gauge tho, not a computer. I don't need it to react fast enough for an ECM..but I do need it accurate. Would a heated one be nessecary?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 24, 2001 | 09:41 PM
JPrevost's Avatar
Car: 91 Red Sled
As long as the tube after the turbo is warm and is getting an accurate reading then you shouldn't need a heated sensor. The heated unit is to help the car get into closed loop faster, but that's if you have efi! I would think your best bet would to get a wideband 02 sensor. I wish I knew if the best place to have an 02 sensor was right after the fins. Sorry I can't help you with that but there is no reason to get a heated 02 sensor unless you plan on going to EFI .
, Jon (350 TBI!)
91 Red My website
Old Aug 9, 2001 | 01:04 AM
Jester's Avatar
This post is old but I wanted to bring it BTT.
The car is running now and I'm not convinced my 02 gauge is reading right. Seems to be rich even when it *should* be lean. I'm not sure if a heated 02 sensor will help me or if I have some physical problem with the Holley on it.
Also what do I tell the parts counter guy I have that will get me a suitable heated sensor for the cheapest?
JSP Motorsports
ICON Motorsports
Old Aug 9, 2001 | 02:00 AM
rezinn's Avatar
You need to find a universal heated sensor.. You could just tell the guy at the parts counter to open the boxes and grab you one with 3 wires. Its gonna be 3 times as expensive as a normal o2 sensor. Im sure you can find one on the internet somewhere.
MSD-8935 81.99 at summit
BOSCH 15703 63.99 at www.kragen.com, thats a 4 wire
BOSCH 13077 85.99 3 wire
After 1993 GM started using heated o2 sensors in everything, so you could just try a 94 corvette or something.
Old Aug 9, 2001 | 02:08 PM
Jester's Avatar
Geez...$65? Ho much can I expect to pay just from the store up the street?
JSP Motorsports
ICON Motorsports
Old Aug 9, 2001 | 03:42 PM
rezinn's Avatar
Probably $75 bucks.
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
fonzie85
Aug 13, 2015 11:50 AM
