Tune Up
Old Jun 8, 2018 | 11:56 AM
ZackZ420's Avatar
Car: 1991 CamaroZ28
Axle/Gears: Stock
Tune Up
I just upgraded my ignition system to MSD Street fire. I got the ignition coil, MSD cap and rotor and MSD street fire plugs. Also got NGK IS Iridium plugs. Put everything in and it runs but will die under load. Don't get it. I'm gonna check the wires. When it start the tach will flicker intermittently. And ideas?
Old Jun 8, 2018 | 02:16 PM
ZackZ420's Avatar
Car: 1991 CamaroZ28
Axle/Gears: Stock
Re: Tune Up
Okay so I put stock ignition coil back in it and it runs fine. Why isn't the MSD coil working. Or do I have to reprogram ECM
Old Jun 8, 2018 | 04:06 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Tune Up
It's not uncommon to get a aftermarket coil bad out of the box. The unfortunate problem is, most place won't accept electronic parts back if the package has been opened. There is no programming needed for a coil change. One thing to try is where the bracket bolts to the coil, scratch up the coil where the little bolts go through on the coil and the bracket to get a good ground.
Old Jun 8, 2018 | 05:20 PM
ZackZ420's Avatar
Car: 1991 CamaroZ28
Axle/Gears: Stock
Re: Tune Up
Well I got a street fire coil and an MSD HEI coil. But maybe ur onto something with the ground. Thanx with troubleshoot
Old Jun 8, 2018 | 08:33 PM
Drew's Avatar
Re: Tune Up
Guarantee the factory parts were an order of magnitude higher quality than most anything you'll find at the corner auto parts store now. "Street Fire" is MSD's economy line, kind of MSD in name only. Pretty sure that when you asked for advice a couple weeks ago, I told you not to waste your money on that crap. Oh well, if it runs better with the old stuff, switch it back.
Double check your firing order and connections. Easy enough to make a small mistake. That said, if it runs better after only switching the coil back, run the original coil.
fasteddi
Mar 27, 2015 02:41 PM
sidwyz
Dec 20, 2013 11:11 AM
FiReBReTHa
Aftermarket Product Review
Mar 11, 2001 08:02 AM
Josh 91RS
Dec 1, 2000 10:26 AM
