fuel pump and gauge connector
Anyone know the what kind of connector belongs on a factory in tank fuel pump/sending unit? I guess since the previous owner carb swapped this and installed a motor mounted fuel pump he just disconnected and left the wiring hang.
Well, it must've been sitting on an exhaust pipe because the whole connector is melted.
If i had to guess it looks like a 3 pin weatherpak connector, but the one i ordered doesn't plug into the plug on the body. Looks like the body plug is keyed differently?
Any idea? I'm really not trying to replace a sending unit because of this.
Thanks.
Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: fuel pump and gauge connector
You will need to compare the slots on the connector but this might be the male side.
https://www.corsa-technic.com/item.p...category_id=83
You can always change them to this
https://m.ebay.com/itm/K4-3-Circuit-...oAAOSw8DJaPPui
Car: '89 Firebird
Engine: 7.0L
Connector that mates to the plug on the firewall side (behind rear seat) is Delphi part number is 12020829. I usually go to Ballenger Motosports for small purchases like that.
I don't know the part number for the fuel pump side.
bwmcam
Mar 23, 2016 01:28 PM
82Brlinetta
Feb 14, 2016 08:53 PM
kowboy59
Nov 7, 2011 09:36 PM
FormulaLT
Sep 18, 2011 03:49 PM
Cameron
Oct 6, 2004 08:15 AM
